USB-6003 Access using Node-Red.
I have an application where a USB-6003 module is being used to acquire pulses and control two digital switches.
I have a request from an instrument tech, that does not use LabView but rather uses Node-Red for IOT system control.
Are there notes available which describe how to connect the USB-6003 to systems other than LabView?
Thanks for any pointers.
(249 Views)
At the core is the c-dll for the DAQmx driver which is called using wrappers in the common programming languages. To add support in a new language you need call the c-dll in that language (Node-Red).
https://www.ni.com/en/shop/software-portfolio/hardware-drivers-the-key-to-nis-software-connectedness...
Santhosh
Soliton Technologies
(224 Views)
