Unable to see Newport ESP301 USB instrument in VISA resource list
I am trying to communicate with a Newport ESP301 controller via USB, using the NI-VISA or PyVISA library.
Here is some information about my machine:
python -m visa info
Machine Details:
   Platform ID:    Linux-3.16.0-53-generic-x86_64-with-debian-jessie-sid
   Processor:      x86_64
Python:
   Implementation: CPython
   Executable:     /usr/local/bin/python
   Version:        2.7.10
   Compiler:       GCC 4.8.4
   Bits:           64bit
   Build:          Nov 24 2015 14:35:43 (#default)
   Unicode:        UCS2
PyVISA Version: 1.8
Backends:
   ni:
      Version: 1.8 (bundled with PyVISA)
      #1: /usr/local/vxipnp/linux/lib64/libvisa.so:
         found by: auto
         bitness: 64
         Vendor: National Instruments
         Impl. Version: 15728640
         Spec. Version: 5243904
   py:
      Version: 0.2
      ASRL INSTR:
         Please install PySerial to use this resource type.
         No module named serial
      TCPIP INSTR: Available
      USB RAW: Available via PyUSB (1.0.0b2). Backend: libusb1
      USB INSTR: Available via PyUSB (1.0.0b2). Backend: libusb1
      GPIB INSTR:
         Please install linux-gpib to use this resource type.
         No module named gpib
      TCPIP SOCKET: Available
lsusb:
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 008: ID 104d:3001 Newport Corporation
Bus 003 Device 007: ID 04b3:310c IBM Corp. Wheel Mouse
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID 04f2:b217 Chicony Electronics Co., Ltd Lenovo Integrated Camera (0.3MP)
Bus 001 Device 004: ID 0a5c:217f Broadcom Corp. BCM2045B (BDC-2.1)
Bus 001 Device 003: ID 147e:2016 Upek Biometric Touchchip/Touchstrip Fingerprint Sensor
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Attempting to use the PyVisa library:
>>> import visa
>>> rm = visa.ResourceManager('@py')
>>> rm.list_resources()
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "/usr/local/lib/python2.7/site-packages/pyvisa/highlevel.py", line 1560, in list_resources
    return self.visalib.list_resources(self.session, query)
  File "/usr/local/lib/python2.7/site-packages/pyvisa-py/highlevel.py", line 238, in list_resources
    raise errors.VisaIOError(errors.StatusCode.error_resource_not_found.value)
pyvisa.errors.VisaIOError: VI_ERROR_RSRC_NFOUND (-1073807343): Insufficient location information or the requested device or resource is not present in the system.
>>> exit()
Attempting to use the NI-VISA library:
>>> import visa
>>> rm = visa.ResourceManager()
/usr/local/lib/python2.7/site-packages/pyvisa/ctwrapper/functions.py:1225: VisaIOWarning: VI_WARN_CONFIG_NLOADED (1073676407): The specified configuration either does not exist or could not be loaded. VISA-specified defaults will be used.
  ret = library.viOpenDefaultRM(byref(session))
>>> rm.list_resources()
(u'ASRL5::INSTR',)
>>> exit()
Why am I unable to see the USB instrument in the resource list? Any help is appreciated. Thank you in advance.
(5,467 Views)
Have you ensured you configured the NI-backend correctly?
Review these processes:
https://pyvisa.readthedocs.org/en/stable/configuring.html
If you are sure this has been done correctly, consider the following:
Have you been able to communicate with this device before?
Do you have another USB device you could try using to verify the ports and wires are working properly?
Do you have a different machine you could try it on?
Eric
(5,425 Views)
