08-08-2012 04:04 AM
hello,
The signal generator is the Agilent (33120A)
In Measurement & Automation which have caught this device (see below)
But VI execution to half Shique the following error window
in Initialize.vi, there is a problem
Such as photos
Seems to be unable to distinguish the devices?
How can i solve this problem? thanks~
08-08-2012 10:22 AM
Hi
Noticed that you are using serial port to communicate to instrument. Would you please double-check the serial setting parameters, such as Baud Rate, Flow Controls and etc. are insistent with the configuration on instrument? Or would you please try to use other interface rather than serial port.
If you have tried everything I mentioned above and it still raised that error, please manipulate the NI I/O Trace (You could find it in Windows Start menu) tool to trace and log the communication between PC and instrument. I should be helpful to analyze the root course if you investigate into that trace log. It would be great if you post it here!
- Charles
08-08-2012 12:37 PM
08-09-2012 04:27 AM
HI,
I check my baudrate is accurate(9600)
08-09-2012 04:33 AM
HI,
i check
serial port , Baud Rate(9600) , Flow control , parity are all correct
However, I found a strange thing
I run this vi several times
Will not appear on the error message, and do not know why? = =lll
08-09-2012 08:34 PM
try another computer.
08-11-2012 07:16 PM
What about using NI I/O Trace to get the trace information?
08-14-2012 07:16 AM
Thanks all~
I have been solve this question,
I modify this vi , and then it can work.
09-10-2013 05:08 PM
Did you modify the end characters? I'm getting the exact same error.
09-12-2014 03:50 PM
Hi, trying to use a 33120A... exactly the same error.
Was there a resolution posted to this issue?
The tread ended but nobody posted the solution.
What was the change to teh VI?
catalin
