12-20-2015 07:58 PM - edited 12-20-2015 08:13 PM
I am working on a project in which I am required to do the following:
I am working on labview from a couple of days. I am trying to learn as much as possible frm the resources on Ni website. By seeing the tutorials, forums I understood that I need to use VISA for obtaining data from serial port and should use State machine and Queue message handler. Upon seeing the project templates, I noticed that Continuous measurement and logging template is similar to what I need but I am not sure.
And also, Can I use any software to create virtual data without having a physical device connected to a serial port.
Any advice is well appreciated. Thank you.
12-20-2015 08:46 PM
12-20-2015 10:33 PM
Thank you for the advice. Sorry for the confusion, I did nt make it clear in my question. I have two serial ports for the two devices, however I want one lab view application to gather data from two devices using two serial port connections.
Can you please elaborate on how to write data to the port?
Thank you
12-21-2015 06:23 AM
