05-09-2012 02:26 PM
I need to communicate with a Tektronix DSA8200 Oscilloscope with a PC. In the past I have used the NI GPIB PCI card. The only connector available in the Dell Optiplex 790 for parallel communications is a PCI-e 4x. Which NI card should I buy? Will there be problems getting it work with legacy (read old) software?
Thanks in advance for help.
Joe
05-09-2012 03:06 PM
NI has a GPIB-USB adapter that I've started using.
So far it works well... only complaint is the physical size of the adapter. If the connector on the instrument is recessed and close to the edge of the chassis, you'll need to use a cable to go between the connector and adapter rather than just plugging the adapter onto the instrument. Also since the adapter is longer than a standard connector, you may need some additional space in the cabinet to fit that in there.
05-09-2012 03:27 PM
Joe
Why use GPIB when you can use LXI? No new hardware to purchase.
05-09-2012 07:32 PM - edited 05-09-2012 07:33 PM
I think nyc has the right idea by going with the LAN connection. However, NI's PCIe GPIB card is a x1 card and can therefore can go into your x4 slot.
