01-26-2016 08:22 AM
estimado, con esta configuración el programa realiza lo que necesito. El ordenador, envía un dato de temperatura a un instrumento, el cual obedece al dato entregado por el ordenador.
Muchas gracias por la ayuda 🙂
Nota: tengo que configurar una conexion ethernet...¿Por casualidad me podria orientar con respecto a una conexion entre instrumento y ordenador, a traves de cable ethernet, pero no haciendo uso de la red de internet? De ante mano gracias.
01-26-2016 08:31 AM
01-26-2016 08:53 AM
Dear, with this configuration the program it does what i need. The computer sends a data of temperature to a instrument, it reads and obey.
thank you for your help!
Note: Now, i have that configure a connection type ethernet...¿You can guide me? Is a connection computer-instrument via wire ethernet but not using red internet...
01-26-2016 09:33 AM
01-26-2016 12:30 PM
for the test, i,m using the instrument AMETEK RTC-157, i not find drivers for this instruments.
I'm using TCP and see...
01-26-2016 12:39 PM
01-27-2016 12:47 PM
Because i do setting a connection via ethernet where send datas of temperature from the computer to instrument.
Not use MAX, only connection for TCP
¿why the syntax? don´t understand 😞 ...
01-27-2016 02:36 PM
01-29-2016 11:31 AM
I don´t find that information. Can connect computer with instrument which register address IP and is recognized for the computer, send test ping for DOS and port ethernet is ok! but i have problems with port assigned for computer and syntax to data...
01-29-2016 11:53 AM
