controling a DC power supplies (hp 66000 Mps mainfram)
controling a DC power supplies (hp 66000A Mps mainfram) via labview by using GPIB- USB. so I will do project to control 8 power supplies by using Labview programme:
1-how to connect power supplies with PC by GPIB - USB?
2- how to start in Labview programme?
3- please give me some advices you see that is important for my project?
thank you.
(4,553 Views)
Accepted by topic author Mo7mmed
Please use Help> Find Instrument Drivers.
Connect the cable to the main frame. Hopefully you have an NI GPIB controller. It will be easier to use.
See http://www.ni.com/downloads/instrument-drivers/ for information on how to use a driver.
(4,547 Views)
1) If you can't even figure out how to connect up a GPIB, you are in trouble.  It is fairly obvious where the GPIB end goes and then the USB goes into your computer.
2) LabVIEW Basics
LabVIEW 101
3) Start by downloading the LabVIEW driver for it: Agilent 66XXX Series Power Supply
GCentral
(4,543 Views)
