11-28-2019 07:49 AM
Has anyone controlled dS2824 - 24 x 16A ethernet relay through labview. If controlled please share me procedure with some examples.
Thanks in advance
11-29-2019 10:25 AM
Is your boss willing to pay for provided code?
11-29-2019 12:10 PM
11-29-2019 01:12 PM
The manual seems pretty clear on how to set up the device and the commands to write to it. Personally, I would set it up to use the ASCII commands and it is quite simple from there.
11-29-2019 02:07 PM
@crossrulz, exactly. The hardest part will be to set up the networking either as a private VLAN or on the public network with a DHCP. The communication is just ordinary command/response.
It appears to use port 17123 (according to a figure, but not documented!!) and default to an address of
192.168.0.123 so you need to make sure that your computer is on that subnet unless you have a local DHCP server.
then just use a visa address of TCPIP::192.168.0.123::17123::SOCKET and off you go!
