how to control laser doppler vibrometer via ethernet
Here you posted a documentation of the telnet protocol to control the LDV.
What parameters do you need to control?   (Note: I didn't ask what you what to control 😉 )
Where did you run into trouble?
May I ask for your application?  (I use LDV for ~10a, so I'm just curious 🙂 )
Greetings from Germany
Henrik
LV since v3.1
Message 11 of 21
(2,318 Views)
http://www.optomet.de/en/products/swir-dual-fiber-vibromter/
this is the vibrometer link
OptoMET Dual Fiber SWIR Vibrometer
Message 12 of 21
(2,307 Views)
till changing the controls via ethernet i had done but fetching data we use oscilloscope
but we want  to get live data through ethernet and then going for further signal processing via filters ....
company has poor documentation of there own driver and hey might had assembled some third party hardware  which they donot want to mention and present any knowledge
i still have option to use analog to digital converter from NI but my company donot want to invest more on this.
application is to monitor very small vibrations in devices which company makes
Message 13 of 21
(2,306 Views)
please send me emil so that i can send you the driver
Message 14 of 21
(2,303 Views)
Sorry, I don't need your driver since I don't have your hardware 🙂
I was curious about what you are measurering with the LDV.
So you get information from the manufactor on how to control it but not how to read data?
The wiresharc tool has already been mentioned...
Henrik
LV since v3.1
Message 15 of 21
(2,294 Views)
yes you got it utill controlling manufacturer can help but how to get data he himself dont know only one software guy in his company.
i will try wiresharc this weekend
Message 16 of 21
(2,289 Views)
this is what i got from the company on 6 th of oct
Message 17 of 21
(2,272 Views)
I remember playing around with udp ...   it's like the unit (LDV) is just crying out the values on the ethernet wire to everyone hooked on.
LabVIEW can read udp packets.
time for a producer consumer vi  🙂 read the raw data (producer) and parse it to values (consumer) .With the format provided you can write your parse stateMC.
Reading the wikipedia article and LV-Help give further information.
If you run into problems; remember to attach some udp raw data packets ...
Henrik
LV since v3.1
Message 18 of 21
(2,264 Views)
I tried to read data via udp in labview while watching an example. first it gave error 56  now it gives 63 with buffer overflow. i am using udp first time and have no idea about it.
here i attached  .vi wireshark and error
Message 19 of 21
(2,249 Views)
Accepted by deutchland
Don't know where the error is comming from... Blocksize??
From the wireshark file i could extract blocks ...    however the 20MHz samplerate seems too fast so an discontinued data flag is showing if I interpret rigth 🙂
I attached the vi ... but it's really quick and dirty 🙂    the real decoding shouldn't be done with the scan for tokens since the datablock can contain any data...including the token I used 😉
Henrik
LV since v3.1
Message 20 of 21
(2,233 Views)
