06-07-2006 11:42 AM
06-08-2006 08:50 AM
06-08-2006 09:41 AM
The control that you've entered the VISA resource name into is the old string control that is no longer wired to anything. Go back to the diagram and delete it. Go to the actual VISA Resource Name (the brown colored control), right click on it an select Show Control. Find it on the front panel. Using the wiring tool, connect this control to the upper leftmost position on the VI's connector pane.
I'm still not sure what exactly is going on. The llb I attached had the correct wiring and everything else for the initialize function.
06-08-2006 09:59 AM
06-08-2006 10:24 AM - edited 06-08-2006 10:24 AM
If you right click on a VI's icon, you can select "Show Connector". You have to wire controls and indicators to this connector pane in order to send/get data from a main VI to a subVI. To make a connection, you use the wiring tool. Click first on a blank connection in the connector pane and then on the control/indicator.
Message Edited by Dennis Knutson on 06-08-2006 09:25 AM
06-08-2006 10:32 AM
