04-17-2012 04:47 AM - edited 04-17-2012 04:50 AM
Hi there, I am trying to control the power supply via IVI-C API.
To get started, I followed the tutorial given by IVI foundation. (http://www.ivifoundation.org/downloads/IVI%20GSG%202012/IVI%20GSG%20C++%20MAR2012.pdf)
I followed the steps given by the tutorial, and could compile and build the application on win32 platform.
However, when building the same project on x64 platform, I kept receiving these errors:
error LNK2001: unresolved external symbol TQLP_InitWithOptions.
May you please tell me whether I could build the IVI API based application on x64 platform? If yes, how to solve this problem?
I have been spending lots of time in solving this link error problem. Any tips or help would be deeply appreciated.
Many thanks in advance for your help.
04-17-2012 07:37 AM
Hi jwsun,
Which IVI-C driver are you using? If the IVI-C driver has a .lib file (I guess it should be TQLP.lib) under "C:\Program Files\IVI Foundation\IVI\Lib_x64\msc\", please make sure if this lib has already been added into the Link input path.
04-17-2012 07:46 AM
Hi, Charles.Tac,
Thanks for your reply. 😃
I am using the IVI-C driver given by TTi (QL_IVI Driver-v1.6.0), and yes it is TQLP.lib. I have also added into the input of the linker.
One thing I forgot to mention is that I am using 64bits Win 7. Thus following the instruction given by the tutorial, the lib is supposed to be C:\Program Files(x86)\IVI Foundation\IVI\Lib\msc\. For this path, I could find the TQLP.lib.
However, for the path you mentioned, I could not find the TQLP.lib.
So, which path should I add into the additional lib directories for the linker?
Thank you again for your kind assistance 😃
@Charles.Tac wrote:
Hi jwsun,
04-18-2012 02:11 AM
Hi jwsun,
There should be two seperate lib file for x86 and x64. Could you make sure if you are using the correct lib in linker?
Please open a Visual Studio Command Prompt and type "dumpbin /HEADERS xxx.lib >> a.txt". Search the string "FILE HEADER VALUES" in a.txt, you could find the OS platform the lib support.
Wish that could help.
