08-08-2011 08:04 AM
Dear all
To run a function generator HP 33120 by Labview, I downloaded a driver "Agilent 33XXX Series", also attached with this message. But the vi files (e.g. "Standard Waveform.vi" or "Arbitrary Waveform.vi" ) available in this driver, dont allow the function generator to generat a signal of more than 1 kHz, while I need about 200 kHz. Manually the function generator can easily generate a signal of 15 MHz.
So I need a driver/vi of this function generator which can make it generate a signal at about 200 kHz. Kindly help me.
Thanks in advanced
Regards
Faheem
Solved! Go to Solution.
08-08-2011 09:57 AM
The driver does allow you to set any frequency. What makes you think you cannot?
08-12-2011 05:20 AM
Dear Dennis
I think I had hardware problem where I was able to change frequency from 1000Hz to 999Hz and so one but I was unable to increase from 1000Hz to 1001hz and so on. But now it is solved.
Thanks again
