07-27-2008 04:51 AM
07-28-2008 08:49 AM
What type of connection is there for the instrument? GPIB, serial, Ethernet, USB? Do you have a manual for the instrument that explains how the communication is supposed to work? Can you attach an electronic copy or a link to it?
What Agilent software are you using and how is that relevant to this question?
07-28-2008 11:07 AM
>What type of connection is there for the instrument? GPIB, serial, Ethernet, USB? Do you have a manual for the instrument that explains how the communication is supposed to >work? Can you attach an electronic copy or a link to it?
Thanks for answer. I use connection by using serial port. Manual is present and I can communicate with this device using the special program but for me it is inconvinience because for measurment I use another device. And these two devices must work in paralel to each other. The reason why I use Aglient IO Libraries Suite is to communicate with another device that I mentioned above.
I add realization of communication using the Labview. But here used some DDE. I was unsuccsesful to find in labview vi-files that uses DDE.
Best ragards
07-28-2008 11:31 AM
07-28-2008 11:41 AM
01-27-2016 10:47 AM
You can find the labview software at this web site :
http://neel.cnrs.fr/spip.php?article149&lang=en
Best regards
