JKI State Machine Objects
JKI state machine Explorer
There is a quick question about JKI state machine explorer. I know it was rolled out in JKI state machine 2018. Whar's the labVIEW version will be compatibale with this feature? I have LV2019 which is working fine with Explorer. However it looks like not be able to launch on LV2014.
(5,420 Views)
Accepted by TwinCoast4K
According to the package installed on my machine, the JKI State Machine 2018 version is compatible with >= LV2013
The Editor seems to also be compatible with LV2013 and up, according to info on Github:
https://github.com/JKISoftware/JKI-State-Machine-Editor/blob/master/source/JKI%20State%20Machine%20H...
GCentralChampionCLA
(5,386 Views)
Right-click menu plugins don't work in LabVIEW versions older than 2015. You can launch the JKI SM Explorer with QuickDrop Shortcut via Ctrl+Space >> Ctrl+J
(5,381 Views)
Hi Jim, there is another question just for my curiosity. I use JKI SM a lot recently and used lots of dynamic event creation feature from framework. The question is how did you get that automatically wiring done (which create different state, wiring registration, un-register the dynamic event...). Is it done by using some feature in LabVIEW or you using another lower level language to automate it. Thanks.
(4,832 Views)
I'm not the Jim that you're looking for, but I can say that LabVIEW VI scripting was used.
Jim
(4,826 Views)
