06-29-2021 02:33 AM
This used to work in LV18, now in LV20 (and 21 beta) this brakes in some situations:
I'm sure there's some logic behind it, but AFAIC, it should just work...
The error in\error out + OR is the simplest situation where it breaks, even in a new VI.
The problem is only there for 1 input. Extracting the node unbreaks the wire.
06-29-2021 07:28 AM
Could it be related to this issue discussed on LAVA that resulted in bug ID 1289111 ?
LabVIEW is not correctly determining when it needs to recompile/save the VI when switching between RT and Windows
Epictetus
06-29-2021 08:07 AM
That LAVA content is hidden (from me).
But there's no RT involved at all.
06-29-2021 09:14 AM - edited 06-29-2021 09:15 AM
This was posted publicly a little while ago where it was ignored, and then forgotten by the author (me). No CAR or bug was assigned.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
06-29-2021 10:22 AM
It shows once you log in. (Not sure why Lava is configured that way, but it will prevent finding it using a google search 😞 )
I agree that's quite a different problem. (At first glance it resembles this report, but probably not the same cause)
06-29-2021 11:01 AM
06-29-2021 01:16 PM
Almost certainly related to the feature which is supposed to break wire branches instead of the entire wire.
06-29-2021 01:49 PM
I've created Bug 1518595 to track this issue.
