LabVIEW 2021 Public Beta
Composite OR error weirdness
This used to work in LV18, now in LV20 (and 21 beta) this brakes in some situations:
I'm sure there's some logic behind it, but AFAIC, it should just work...
The error in\error out + OR is the simplest situation where it breaks, even in a new VI.
The problem is only there for 1 input. Extracting the node unbreaks the wire.
Message 1 of 8
(2,890 Views)
Could it be related to this issue discussed on LAVA that resulted in bug ID 1289111 ?
LabVIEW is not correctly determining when it needs to recompile/save the VI when switching between RT and Windows
Epictetus
Antoine Chalons
Message 2 of 8
(2,845 Views)
That LAVA content is hidden (from me).
But there's no RT involved at all.
Message 3 of 8
(2,840 Views)
This was posted publicly a little while ago where it was ignored, and then forgotten by the author (me).  No CAR or bug was assigned.
Message 4 of 8
(2,832 Views)
It shows once you log in. (Not sure why Lava is configured that way, but it will prevent finding it using a google search 😞 )
I agree that's quite a different problem. (At first glance it resembles this report, but probably not the same cause)
Message 5 of 8
(2,821 Views)
Let's hope it gets some attention now...
Message 6 of 8
(2,812 Views)
Almost certainly related to the feature which is supposed to break wire branches instead of the entire wire.
Message 7 of 8
(2,800 Views)
I've created Bug 1518595 to track this issue.
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 8 of 8
(2,794 Views)
