02-26-2016 09:33 AM
I am trying to turn off Automatic Gain Control at usrp n210 but i can't.How to disable AGC?
02-29-2016 12:33 PM
From what I could find, the AGC is part of some daughterboards. What daughterboard are you using?
02-29-2016 03:47 PM
I am using SBX daughterboard.
02-29-2016 04:05 PM
Are you sure that your currently using AGC?
According to https://www.ettus.com/content/files/kb/Selecting_an_RF_Daughterboard.pdf, only the TVRX2 has built in AGC.
03-04-2016 04:13 PM
I am trying the removing noise in the sound file.So,I tried turn off the AGC at USRP.How can I solve this problem?
Thank you.
03-04-2016 05:33 PM
Hello Ozgur,
Can you please show me where it indicates that you are using AGC?
Are you trying to reduce the noise in a signal that you are outputting or a signal that you are loading from a file?
03-05-2016 04:13 AM
I am not using the AGC.Just,I wanted to turn off for removing noise.This is my FM Demodulation code.I want to removing noise in this code by using threshold but i can't.Can you help me?
Thank you.
03-07-2016 09:27 AM
Hello Ozgur,
I am very confused.
I don't think that the N210 with SBX has a built-in AGC, so it is already disabled. If you have found documentation indicating that you are using a AGC, please link the document here.
How are you planning on using a threshold to reduce noise? I recommend confirming that your radio is recording in your signal of interest and using a bandpass filter to isolate the frequency of interest. This will remove most of the noise. Once you have the frequency isolated, you can demodulate the signal.
