03-06-2023 01:42 AM
Hello,I have two questions.
1. Is “LabVIEW Communications System Design Suite” and “labview NXG” the same thing?After I downloaded “LabVIEW Communications System Design Suite”,there is only “Labview NXG” ,and the upper right corner of its interface reads “labview Communications System Design Suite”.But in my NI package Manager there is no “labview Communications System Design Suite”.I'm confused.
2.I want to find the example"USRP-2974 Single-Device Streaming",but I can't find it in Labview NXG,as shown in the screenshot。Could you tell me where it is?
Thank you in advance.
03-07-2023 06:20 AM
Hi lunaming777,
1. For question is “LabVIEW Communications System Design Suite” and “LabVIEW NXG” the same thin, answer is no.
"LabVIEW Communications System Design Suite" combines "LabVIEW NXG" with tools that are specifically created to help you rapidly prototype wireless communications systems.
2. You should download "LabVIEW Communications System Design Suite" and drivers as well and complete one or more of the following options to detect your device in LabVIEW Communications System Design Suite:
Regards)
________
Best way to thank is to give Kudos / Mark as a solution.
03-07-2023 11:56 PM
Wow!I see~
Thank you very much for your answer!
