04-07-2020 02:35 AM
Hello.
I'm currently using LabVIEW Communications 4.0 Trial version to test on my PC before purchasing it.
However when I tired to run example project, USRP RIO 40 MHz BW Single-Device Streaming, there occurs an error that says "Cannot find or load shared library lvanlys.dll"
How can I solve this problem?
The equipment that I use is as follows.
Processor : AMD threadripper 3960x
RAM : 32GB
OS : Windows 10 64x
USRP-2953R
Thanks a lot.
04-07-2020 10:29 AM
Hi RobCo,
Can you confirm that the DLL is present at the following location on your system? If it's not, you may have a bad installation (which seems unlikely).
C:\Program Files\National Instruments\LabVIEW NXG 4.0\Win64\lvanlys.dll
If that file is present, it may be that the evaluation licenses you currently have active don't support the analysis library functions as described here. Make sure your evaluation covers LabVIEW NXG Professional in evaluation mode when you look in the NI License Manager.
If neither of those get you any further, I'd recommend reaching out to NI Support through the official channels (I.E. Request Support on this page).
04-08-2020 03:49 AM
Thanks !
I solved this problem by setting an environmental variable. MKL_DEBUG_CPU_TYPE=5
( refer to this link : https://forums.ni.com/t5/LabVIEW/error-loading-lvanlys-dll-in-Labview-64-bits/m-p/4009772 )
I guess this problem occurs with AMD CPUs.
