LabVIEW Communications System Design Suite
MIMO Channel estimate in Lab view Communications
I am designing 2*2 MIMO using USRP 2952. I need to do beamforming at Transmitter. Do we have any already implemented block in either of the projects/examples which does channel estimate and precoding?
(4,486 Views)
Hi Wired_,
Yeah, a group at Imperial College London created an AoA application. You can check that out:
Angle of Arrival Detection with NI USRP RIO
https://decibel.ni.com/content/docs/DOC-25716
Here is some other related info:
Configuring Phase-Coherent RF Measurement Systems: From MIMO to Beamforming
http://www.ni.com/white-paper/9127/en/
Cheers,
Michael
Michael Bilyk
Former NI Software Engineer (IT)
(4,460 Views)
I seriously doubt AOA and beamforming are same!
AOA is cosidered with respect to an atenna array. So it's like the angel at which anteena array should physically steer power in the direction of the receiver.
Whereas to have beamforming we need to include channel and mutipath effects and form a precoding vector.
Let me know if I am thinking in right direction.
(4,394 Views)
True, but I think it will be your best starting point.
Cheers
Michael Bilyk
(4,346 Views)
Accepted by Wired_
Hi Wired_,
After looking into it further I found a related forum post involving channel estimation.
https://forums.ni.com/t5/LabVIEW-Communications-System/Channel-Estimation-using-the-SISO-TDD-OFDM-Vi...
Cheers
Michael Bilyk
(4,334 Views)
