10-24-2016 10:47 AM
Hello.
I'm trying to create a socket server on Labview to comunicate with a PLC.
I can create a conection and exchange bytes betewen PLC and Labview, but when the server is not exchanging data, the vi does anything.
In the vi I put a button to turn on the lamp, and until the "start listening" button is off, I can turn on and off the lamp, but when I turn on the "start listenning" button the lamp can't be switched.
There are some way to use socket comunication and continue controling the rest of vi?
10-26-2016 02:55 PM
Hi alvarosj,
This forum is for LabVIEW Communications System Design suite, which is different from LabVIEW. It appears that this questions should be posted on the main LabVIEW forum here: https://forums.ni.com/t5/LabVIEW/bd-p/170.
If you are using LabVIEW Communications, please post a .gvi file so we can troubleshoot.
Ben C.
RF Systems Engineer
