12-13-2024 05:02 AM
Tell me how can I integrate PTC air ceramic heater in LabVIEW through LINX.
12-13-2024 10:11 AM
You need to define all terms such as "integrate" and "through". LabVIEW and LINX are both software components. Please add a few paragraphs describing the hardware you have and what you are trying to achieve (remote on/off? PID control? scheduling?).
It is not clear why you are posting in the "LabVIEW communications system design suite", because this is probably not the correct software for this.
12-24-2024 11:25 AM
PTC ceramic air heater runs on mains AC (consumer heaters) and you can control it through electromechanical relays or SSR, you need to appropriately choose the relay rating higher than the heater power consumption. Now, you can connect the relay to Arduino to a digital output, now use the LINX toolkit to set the digital pin state to high or low to control the relay which in turn controls the heater.
