03-26-2019 12:07 PM
Hi All,
When I am trying to install LabVIEW Communication System Design Suite 3.0 in Windows 10, I got an error "command line option syntax error".
03-26-2019 08:13 PM
Hi A87,
The error "command line option syntax error" can be caused by using a user name having double-byte characters in it.
Please check the following web link:
Thanks.
03-27-2019 01:54 PM
Hi @A87,
Where in the install process are you seeing this? Is the installer able to complete at all?
To doublecheck, does this occur when running as an administrator? Additionally, do you have a second computer you can test the install on?
I would reccomend checking with your IT (if you have some) to make sure they dont have antivirus or some other blocks on.
If it continues, please call give our support line a call!
Best,
Chase E.
03-27-2019 02:52 PM
Hi Chase E.,
The error occur as I double click on the executable file.
The system is independent and firewall is OFF.
When I double click on the executable file, a pop of window is open which shows "command line option syntax error" and at the top of the window it shows "NI package manager offline installer".
Thanks.
