I am trying to create an image of my PXI controller (PXI-8101) using the NI RAD Utility. When I do this I get the following error message:
Steps to reproduce
- Select PXI from the list
- Press Retrieve
- New Application Image - Provide Name "PXI-BACKUP"
- Press OK
- Provide path to C:\Users\<username>\Downloads\PXI-BACKUP1_0_0.lvappimg
- Press Retrieve image from ......
- Then my error appears
Research
I haven't had much success in finding anything through google search.
I found a forum post from 2020 asking the same question with no answer.
LabVIEW Error suggests
Error -2147220623 occurred at an unidentified location
Possible reason(s):
NI System Configuration: The property does not exist for this resource.
Other similar RAD Errors - none match what I am seeing
Error -2147220321 in NI RAD Utility
Error -2147220354 in NI RAD Utility - NI
Error -2147220622 When Using the RAD Utility - NI
Questions
- What property does not exist?
- Why am I getting this error?
- How can I get an image of my PXI?
Thank you in advance
K
