08-17-2016 02:01 PM - edited 08-17-2016 02:02 PM
I would like to know if anyone has found examples for this pairing of components. Or if they have any project examples they can share.
Thanks.
Solved! Go to Solution.
08-17-2016 02:54 PM
Have you looked at the example that ships with LabVIEW? You can find it in the example finder under Hardware Input and Ouput » FlexRIO » IO Modules » NI 5783
Note that you need to have FlexRIO 15.6 or newer to use the module and see the example, since this was when support was added for the 5783 🙂
08-26-2016 02:04 PM
Thanks for the help. I had to make a lot of changes to it, but I'm getting it to work.
