03-22-2010 04:45 AM
03-22-2010 04:57 AM
03-22-2010 05:05 AM
i have PCI 7830R card available. can you give me any links or related material on how to go about using it.
03-22-2010 05:22 AM - edited 03-22-2010 05:24 AM
You got a multi function FPGA card.
Here you have to implement SPI protocol on DIO lines of FPGA card. Make sure your SPI implementation is optimized to use the DAQ functionality(You just got 1Million gates for your FPGA card.)
You should install Labview RT and FPGA with PCI -7830 drivers.
NI R Series Multifunction RIO User Manual.
03-22-2010 07:05 AM
03-22-2010 08:28 AM
03-22-2010 09:01 AM
03-22-2010 12:10 PM
I would suggest you to implement an intermediate buffer(separate 1D array for MISO and MOSI) between logging application and FPGA application to sync high speed acquisiton and low speed logging.
Never used Beagle though good to have a third party bus analyzers to verify your acquired data . I would really appreciate if you let us know the progress :)...
03-22-2010 12:20 PM
12-28-2023 09:23 AM
you can use a logic https://usd.saleae.com/products/saleae-logic-8
Boone
