When debugging FPGA code, I still like creating debug code right there in the FPGA code with FP debug indicators. After some simulation I can then compile (the exact same code) and test with hardware.
The IDE, however, makes my life really hard. In the background, each VI has a default build spec or bitfile associated with it. When a tiny tiny change occurs in the source code (some of which seem overly sensitive BTW) the interactive mode will not start.
It would be nice if we had the option, assuming that the FP controls are identical, that we can start an interactive mode where the existing bitfile is used with the same FP of the VI source. A visual indicator that the bitfile MAY NOT be identical with the code would by a good idea. Sometimes changes are trivial, sometimes when fixing a bug, we might want to double-check old behaviour for a moment before starting a compile process. The ability to maintain the option to execute the last compiled code seems like it would be a nice addition.
And yes, we could make a RT app which interacts with the FP elements but since debugging code changes often (including FP elements), this is a problematic maintenance issue.
