Basically I want a VI like open FPGA VI ref which takes a RIO interface and returns a reference, except that it doesn't deploy a reference if one doesn't exist. It would instead pop out a boolean or error if you try to get a reference and there is no bitfile already deployed.
Two use cases I have in mind:
-Imagine if you need a cRIO to start working ASAP so you deploy your bitfile to flash and tell it to run on power-up. You still have to package the exact same bitfile with your RTEXE, even though its already deployed. This increases the size of your RTexe significantly. Lets say you version your RTexe and don't version the FPGA deployed to flash. Depending on what the signature check is, obtaining a reference to your bitfile may cause the "new" bitfile to be redeployed, eliminating the advantage of loading your bitfile onto flash in the first place.
-Imagine if you have a framework like veristand where you need to use a single bitfile in multiple locations which were written by different developers and possibly released at different times. The tools on NI labs (https://decibel.ni.com/content/docs/DOC-35574) help a lot and let you, once you have a reference, confirm the reference has all the interfaces you need to run your code. However, if you need to share references between code modules you must still be sure to obtain it in just one place and then share the reference yourself using a global or FGV.
Having the RIO driver solve this would be very helpful.
