The document High Performance FPGA Devleoper's guide lists a parallelized bubble sort. I tried this out, and found that it actually doesn't work. This this matrix successfully gets the max value on top, and the minimum value on the bottom, it doesn't completely sort the values between.
In this example, if the highest value started at the end of the array (red), and the 2nd highest value started 2nd from the end (pink), the high value ends up at the top, and the 2nd highest value ends up 3rd from the top.
This lattice can be completed to sort the middle sections by adding 3 more columns, one with 3 Min/Max blocks comparing the center 6 values, one with 3 Min/Max blocks comparing the center 4, and a final Min/Max operation comparing the middle 2. This will complete the sort, but will take 7 sequential steps instead of the 4 listed. The following works to sort the entire array:
