I work with malleable VIs a lot on desktop. They can save a lot of boilerplate code. From my understanding, the entire feature has no effect once code is compiled: the VI is converted to an "instance" VI with the proper data types and inlined into the caller. This doesn't seem like it should be problematic to use on an FPGA target.
Here are a few FPGA-specific wins that I think VIM support would deliver:
- Array size adaptation
- One can imagine writing a "parallel for loop" VIM that simply expands out N parallel iterations for array sizes 0-N
- Fixed point configuration adaptation
- Without VIM, if you write a VI that operates on fixed point numbers, it will auto-coerce to the configuration on the controls of the VI
