I would like to select which FPGA resources (DMA FIFOs, front-panel controls) are used by a host VI at run-time. This would make it possible to implement multiple copies of the same function on an FPGA and control them with the same driver, passing in a reference to the appropriate resources. For example, my FPGA might be communicating with several identical devices over SPI. I'd like to write one host/real-time driver, and then pass in a reference to which front-panel controls to use for that particular device.
It seems like NI has already done some work in that direction, with the FPGA Advanced Session Resources (appears to be LabVIEW 2014 only) and Software Defined Instruments (only on a limited set of boards). I'm looking for a simple interface that's available on all FPGA targets.
