06-05-2015 08:43 PM
I got this when I try to upload the firmware to my 2560. Well I think that my interface is working perfectly because I can upload other projects
I think I installed everything in a correct way but It does not work, can someone help me?
06-06-2015 01:57 PM
You should use LINX because LIFA is no longer supported. LINX also comes with a "Firmware Wizard" which will upload the sketch to the Arduino for you.
http://www.labviewmakerhub.com/linx
You can see the official post about it here.
06-06-2015 04:29 PM
I did install LINX before from
before but I do not know if I still have LIFA installed, if I could see LIFA in the VIPM I could remove the package but I do not actually see it by its own name. As you can see in my screenshot the packages MakerHub LINX and MakerHub Toolbox are installed. What can you recommed me? Should I remove the Labview Interface for Arduino and try to reinstall the LINX again?
06-06-2015 04:41 PM
You don't need to remove LIFA to use LINX. You also don't need to re-install LINX if you have it installed already (unless you are having issues with LINX).
06-06-2015 06:10 PM
Thank you Nathan_B.!
I was wrong following the instructions for the LIFA package instead of following the instructions for LINX. I have to admit that I did not read "GETTING STARTED WITH LINX" from
https://www.labviewmakerhub.com/doku.php?id=learn:tutorials:libraries:linx:getting_started
Install LINX using VIPM.
Installing LINX will automatically install the MakerHub toolbox.
Restart LabVIEW.
Click Tools»MakerHub»LINX»Firmware Wizard…
Select your Device Family and Device Type and click Next.
Select the COM Port associated with your device and click Next.
Select the Firmware Version (it's easiest to start with the Serial/USB firmware) and click Next.
The TX and RX LEDs on your device should appear to be solid on for a few seconds while the firmware is deployed. If you don't see this the firmware was likely not deployed.
Click Launch Example and follow the instructions on the front panel.
This is what I followed to make my 2560 work, I noticed that somebody can get some error is they do not connect properly the cables
Best regards Nathan_B. and you all the comunity!
