03-24-2015 07:43 AM
I'm new in labview using Arduino. I have a reader MF522-AN with SPI bus. I write the code in arduino IDE and works but when i pass to labview, it doesn't work. Any solution.
03-24-2015 07:02 PM
You should use LINX: http://www.labviewmakerhub.com/linx. If you have issues writing LINX code to work with yoru sensor, you should make a post in the LINX forums and attach your VI to your post as well as the Arduino code that you have working.
