LabVIEW Interface for Arduino Discussions
Is there any standard simple ckt which will convert Arduino output (1 to 5VDC) to 4 to 20mA 24VDC loop power?
i have used the below mentioned circuit to convert Aruduino output 1 to 5 VDC in to 24VDC 4 to 20mA.
and provided as a input to I to P converter (which in turns opens control valve).
The drawback of circuit is it drops voltage at 2VDC i.e. 8mA current up to 17VDC. due to which control valve doesnt open up.
at 3VDC i.e. 12mA it works fine.
please provide simple solution.
MMS79
mms79
(4,675 Views)
I use a pwm output, boost it with a ULN2003 to 24V with a 1K 1/2W pullup resistor and drive a PWM input 0-20mA out signal conditioner. HE-X series from Omega. These devices were built to do exactly what you want.
PaulG.
LabVIEW versions 5.0 - 2023
“All programmers are optimists”
― Frederick P. Brooks Jr.
(3,408 Views)
Accepted by MMS79
A DIY suggestion for a 1 to 5 volt to 4 to 20 ma converter.
<http://www.edn.com/design/power-management/4371307/Convert-1-to-5V-signal-to-4-to-20-mA-output>
The circuit requires 3 precision resistors.  The cost of the circuit maybe reduced by using less precision resistors with some loss in accuracy.
hrh1818
(3,408 Views)
Thanks hrh1818,
In trial an error my I to P got some problem,
I replaced my I to P and now it is working absolutely fine.
Once again thanks
MMS79
mms79
(3,408 Views)
