LabVIEW Public Beta Program in 2023
[OSX] open VIs with DAQmx or DAQmx base VIs -> crash
On MacPro 2019 Intel with Monterey
Open a 202x DAQmx base VI, ex: /Applications/National Instruments/LabVIEW 2021 64-bit/examples/daqmxbase/dynamic/ao/Gen Voltage Update.vi
Click "ignore all" when LV looks for missing sub-vis.
Abrupt crash and quit!
I guess it has to do with DAQmx base which tries to initialise some "components" when VIs are loaded.
Same occurs if I try to load VIs with DAQmx for example coming from Windows.
LV should not crash and display missing icons instead,  - or better recompile DAQmx base (at least the USB part) for LV 2023 😉
Ch
(1,562 Views)
Unfortunately, DAQmx Base is no longer supported, so NI will not be fixing issues with these VIs.
Christina Rogers
Principal Product Owner, LabVIEW R&D
(1,542 Views)
Hi Christina
I know DAQmx is not supported anymore, it was supposed to be a joke.
Anyway LV should not crash when opening a VI, no matter what's in the VI!
The same issue occurs if I open a windows DAQmx VI on OSX.
See the enclosed VI.
If opened in LV 2022 I see
In LV 2023b the FP open, and if I try to see the diagram LV crash!
Ch.
(1,528 Views)
