11-19-2017 11:24 PM
24 bit ADC Module for Weight Scale
HX711
OBJECTIVES
The main purpose of this project is to read data from HX711 with NI myRIO. After the main purpose is reached, we will compare the output between myRIO and arduino.
HARDWARE OVERVIEW
Connection Diagram
SOFTWARE
This software is used to program myRIO. The code that is used is inside hx711 myrio.rar
This software is used to program arduino uno. The code that is used is inside HX711 Arduino Library.zip
MYRIO AND ARDUINO COMPARISON
Signal captured with Virtual Bench. The red signal is DT pin and the yellow one is SCK pin.
Arduino signal with Virtual Bench
myRIO signal with Virtual Bench
myRIO no weight
arduino no weight
myRIO 240mL aqua weight
arduino 240mL aqua weight
myRIO 330mL aqua weight
arduino 330mL aqua weight
11-19-2017 11:27 PM
This is the arduino library
11-20-2017 12:25 AM
This is program for myRIO
05-16-2019 01:24 PM
This is exactly what I needed thank you so much
09-19-2019 05:33 AM
hey, very nice. have you made this using DAQ ? because i should submit almost the same work but using labview and daq, and honestly im new to this and i've been looking for something useful and found your work. thnx in advance and nice work
06-07-2021 10:12 PM
Can you share video? How to interface myrio with load cell. I am stuck in VI diagram? Which type of VI circuit is required to make interface?
09-17-2021 04:31 PM
HI, Ty for the code.
Im new to labview and im having a little bit of touble getting the code to run, im having this issuue, Could you help me?
08-23-2022 07:45 AM
Hello, I have practiced it on LabVIEW through the program provided by you, but the result after the program runs is as follows:
As shown in the figure, the values obtained are all - 1. I replaced the two digital signals in the original program with the functions provided by myrio. If you see this message, I hope you can help me see where the problem is. Thank you so much for your help and dedication。
01-19-2024 09:03 PM
Me too. I have the same problem. Please help me.
