LabVIEW Web Development Documents
In web VI, setting output priority
Hello!
I am not familiar with English, so the meaning may not be communicated well.
I want to add a URL image and a string to the cluster so that the string can be printed on top of the URL image.
How can I configure the css?
My development environment
NXG 5.0
Windows Pro 64bit
Comments
MilanR
on
Hi Jively,
Thanks for getting in touch. One thing to note is that this post was created as a Document. Documents are useful to share example code and tutorials. For asking questions you should instead make a Discussion post. In the future you may get more responses by posting LabVIEW NXG WebVI questions in the LabVIEW discussion forum: https://forums.ni.com/t5/LabVIEW/bd-p/170
If the cluster layout mode is configured to None then you can position a String control inside of a cluster on top of a URL Image like the following:
So inside of a Cluster control you can position a String control on top of a URL Image control without using CSS. Is this what you are trying to achieve?
Milan
Contributors
