LabVIEW Web UI Builder and Data Dashboard
Using Labview Technical Data Cloud (TDC)
guys i wanted to use the labVIEW Technical Data cloud (TDC) feature and i have tried getting it... but cant find the correct module or the method to get it for my labview 2011 version.. any help or suggestions on what needs to be done upload vi's and projects to cloud and how to access this feature..
thank you.
(10,363 Views)
metu21,
         I think you might have different expectations for the NI Technical Data Cloud then what is available. There is not an ability to store VIs or projects in the cloud. TDC is used to write data to the cloud. Essientially you replace File I/O API on your block diagram with a new TDC API and instead of writing files to your local drive they get written to the cloud. Hope this helps!
(10,353 Views)
G-Money,
Thank you for explaining it out. Could you tell me how can i access the TDC api??
Regards.
(10,335 Views)
If you click the TDC page that I linked earlier, there is a "Request Access" button in the bottom left corner.
(10,331 Views)
Accepted by metu21
G-Money,
Got it sir. thank you soo much.
Regards.
(10,324 Views)
The Technical Data Cloud (TDC) seems to have been removed.  Is NI not supporting this anymore?
(8,852 Views)
