10-29-2017 03:15 AM
i am looking for a way for the smartphone to impersonate an EV3 brick and to use LABVIEW to program it, all this using the bluetooth protocol,
do you have any suggesions?
thanks,
) Itamar
10-30-2017 02:21 PM
Hey Itamar123,
Can you please elaborate on the application of your project and what you want the functionality of your setup to do. Also, for what reason are you using a smartphone? Typically, smartphones are not used with similar applications to the EV3 brick. There may be a way to communicate to the smartphone, but the functionalities may be different.
Michael B.
Applications Engineer
11-12-2017 10:14 PM
Hi Michael,
I have elementry school kids that know how to program with lab view but dont have the robot, i can build an app on the smartphone the emulate some of the robot feature.
- I
11-13-2017 12:30 PM
Hi Itamar,
I found a white paper that talks about developing Bluetooth applications with LabVIEW. This may help develop a VI that communicates with your phone.
http://www.ni.com/white-paper/3260/en/#toc4
You can also check out some EV3 emulators which run on desktops/ipads. You may be able to adapt your project in order to incorporate this service.
http://www.robotvirtualworlds.com/mobile/
I hope these links can help you with your project.
Michael
11-13-2017 03:00 PM
Hi Michael,
thanks a lot for you answer this really helps!
last question if you dont mind 🙂 , how does lab view ev3 mindstorm identify the brick as EV3 robot? does it have something to do with the bluetooth discovery protocol?
because even if i connect my smartphone to the computer the labview doesnt "see" it as a robot....
thanks in advance,
- I
11-14-2017 08:53 AM
Hi Itamar,
Typically, to identify the EV3 brick click on Tools in the top toolbar, then in the dropdown click NXT/EV3 Terminal then from the top pull-down menu select FIND NXT/EV3. This should open a window to select the NXT/EV3 device.
