古いLabViewはバージョンアップ出来ますか?
過去に購入したLabView2012を使用して計測の自動化をやりたいと考えております。
購入時の担当者に確認したところ、インストールしたPCはすでに破棄されているとのこと。
対応OSもWindowsXPまでとなっており、このままWindows10のPCにインストールしていいものか
そもそもインストール可能なのかがわかりません。
資産としてもったいないので活用したいと考えております。よろしくお願いいたします。
(688 Views)
Accepted by Hide1968
@Hide1968 wrote:
I would like to automate the measurement using LabView2012 that I purchased in the past. When I checked with the person in charge at the time of purchase, the PC I installed it on was already discarded. The supported OS is up to Windows XP, so is it okay to install it on a Windows 10 PC as it is? I don't know if it can be installed in the first place. I would like to utilize it because it is a waste as an asset. Thank you.
Unsupported means that NI R&D does not test or validate it. It might work but it is not guaranteed and there might be some weird behavior.
LabVIEW 2012 is supported in Windows 7 (See the attachment of LabVIEW and Microsoft Windows Compatibility). You can still continue to use it on an earlier supported Windows version. As long as your machine is not connected to internet, you don't have to worry about the security breach due to EOL Windows.
(684 Views)
ありがとうございました。
まずはインストールしてみます。
(642 Views)
