−1073807346 The given session or object reference is invalid.
Hello LabVIEW Community,
i changed the Software of an impedance measuremant device. On the one Notebook it works very fine and on the other with the same LabVIEW Version and the same operating software it doesn't.
When i run the Programm on the PC i always get these Error from one VISA Write:
Can anyone of you please help me?
Kind regards
RubertIV
Message 1 of 9
(10,271 Views)
Sounds like you are trying to write to a serial port that doesn't exist on the second PC.
GCentral
Message 2 of 9
(10,266 Views)
Can you provide more information like what is the device, how the software is accessing it. Do you have the source code of the software? If it is some GPIB device I guess the Resource Name have to be checked. Please show the code for more information.
Message 3 of 9
(10,260 Views)
i use the LabVIEW Versioin 11.0 (32 bit)
and the device is coupled with a GPIB-USB-B adapter
the communication with tthe device and Measurement & Automation Explorer also works on both PCs.
Message 4 of 9
(10,251 Views)
i cant post the code
Message 5 of 9
(10,250 Views)
Show how the instrument appears in MAX. Make sure you show the alias on both.
Message 6 of 9
(10,242 Views)
Message 7 of 9
(10,237 Views)
That shows the controller - not the instrument and for only one pc. Don't even know if that is the one that works or doesn't work. Since you didn't post the requested information, you'll have to do the comparison yourself after checking what alias your program is using.
Message 8 of 9
(10,191 Views)
Accepted by RubertIV
I copied it once more at the pc and now it works, without any changes. i have no idea why
Message 9 of 9
(10,126 Views)
