16 lines of data and truncate to 1 line of data ???
alright my program generates a data of 16 lines as shown below and the following is the block diagram.
 what I need is for it to generate a data with only 1 line shown below.
I think the problem is because of the analog to digital conversion but I think this is the most non-trivial method. it would be great if i can truncate it to 1 line because it's essentially the same thing.
I've also attached my VI if that would be more help. thanks in advance, this wall that I'm running into is annoying me.
(3,302 Views)
Accepted by topic author sdkpark
lol sorry I figured it out again eventually.
rather EXTREMELY simple
you just have to create a constant on the "resolution" of analog to digital and set it to however many bits (in my case 1)
 thanks!
(3,277 Views)
pls can u send the correct vi to me... it may helpful for me...
N. Srinivasan
(3,262 Views)
sorry i got the answer.. 🙂
N. Srinivasan
(3,259 Views)
here it is just incase
as you can see there is a [1] in the for loop
(3,244 Views)
thank you park.... 🙂
N. Srinivasan
(3,220 Views)
thanks i actually needed this
(3,206 Views)
