2us pulse with variable frequency
I need to create the labview code to generate a continuous 2usec pulse where I can vary the frequency from 30hz to 100hz,  any responses are sincerely appreciated. I plan on using the PCIe-6363
(1,082 Views)
Are you looking for instrument suggestions to generate the pulses?
Santhosh
Soliton Technologies
(1,081 Views)
Thank you for replying, I am using a PCIe-6363, need to create the labview code for this continuous 2us pulse at a variable frequency 30 to 100 Hz
(1,076 Views)
Accepted by thomasAnder
I had a few minutes idle time, so here's a little example.
Each time you change the frequency value on the front panel, the pulse train will update but always with a 2 usec pulse width.
Don't have time to explain everything about counters, but this should give you a good head start.
-Kevin P
(1,030 Views)
Thank you, works fine...I made one but it is not as good as yours where yours can change frequency on the fly which is what i will need
(1,023 Views)
