use a slider control, but set the type to integer instead of double and coerce the range from 1 to 3. The slider will then take on one of three values.
to have a 4 way switch. The example gives step-by-step instructions to do that when you click on the Help button (however, note that this example is written for LabVIEW 5.0.1 so some menu options in later versions of LabVIEW are slightly different).
Hope this helps and let me know if you have any questions about it.
Good luck! Shakhina P. Applications Engineer National Instruments
thanks for giving your valuable suggestions but sir what i want is is to have 3 way vertical toggle switch, with unstable position at top, neutral position in center and stable position at bottom. MOST IMPORTANT the shape of the switch should be same as that of vertical toggle switch.
Thanks for the link to your page. In all of my google Labview searches, I hadn't come across your page yet. I think we need a forum section where people can put links to their Labview homepages.
