08-04-2008 04:31 AM
08-04-2008 05:00 AM
08-05-2008 02:26 AM
is there any tutorials to do tht .. im confused in setting the registry ..
is thr any step by step tutorials ..thk u
08-05-2008 04:22 AM
08-15-2008 01:34 AM
hi im still in confuse .. i need a simple help to do this..can any one help me step by step plz.thk u
08-15-2008 02:26 AM
now i know how to create the reg key and check the user enter the valid key or not... but...if the user using evaluation package ..how to check tht he use for 30 days?..
08-15-2008 03:00 AM
Hi jeyanthi,
you can write the start date into your registration key. With every start you can then check if the test period is over or not.
Hope it helps.
Mike
08-15-2008 03:32 AM
thk u but how to do tht.. i can get the install date but how i can knw it 30 days is over ...
let say i install 1-8-2008 and it should b valid till 30-8-2008... if the user change the date in his system ..let say on 29-8 i change my computer date to 1-8-2008 is it it will valid for another 30 days?
can u help me wit this thk u
08-15-2008 03:41 AM
Hi jeyanthi,
you can also write the last data into the registry. If the current date is before the last used date, then someone changed the date and you can react on it. To make it more secure you should think about a server solution.
Hope it helps.
Mike
08-19-2008 09:24 PM
