02-06-2013 11:43 PM
Hello all,
I need to create the process flow diagram for air handling unit consist of motors,pumps, AC rooms in 3D. I never worked in 3D graphics before. Very confused from where to start and how to start.
Suggess me some direction.
02-07-2013 09:22 AM - last edited on 01-24-2025 03:46 PM by Content Cleaner
Ranjeet,
i am a little confused: how does this refer to LabVIEW?
Are you using LabVIEW to visualize the system on the frontpanel (monitoring system application)? If so, do you use LV Datalogging and Supervisory Control Module?
Norbert
02-07-2013 11:20 PM - last edited on 01-24-2025 03:46 PM by Content Cleaner
Dear friend,
This is possible with 3D picture & LV Datalogging and Supervisory Control Module thats why.
02-07-2013 11:21 PM
What link you posted is only for 2012 version & i am using 2011 version.
02-08-2013 01:50 AM
Asking the local NI branch for an older version of DSC is a good start.
Otherwise (if you don't get it or you decide not to purchase it), you can create your custom 3D controls and indicators by customizing controls (advanced >> customize).
Alternatively, you can use a picture ring for displaying appropriate images of 3D elements.
Norbert
02-08-2013 09:59 PM
Hi Nobert,
I tried this DSC module in 2010 in my fried PC, what i found is this image navigator is good for 2D but not for 3D. Then i think that this image navigator is not much useful.
Any other solution for this 3D process flow diagram. I will try this cotrol customization, any document you have on this ?
02-10-2013 10:44 AM
Do you have a 3d model that you can import into labview to start with?
02-10-2013 10:19 PM
Hi unclebump,
No i dont have any 3D model to import to labview. But i downloaded some VRML files & called to labview through load vrml files.
I need to create everything from scratch. Any suggestion.
02-11-2013 12:51 PM - last edited on 01-24-2025 03:47 PM by Content Cleaner
Might want to start with these examples to see if 3D is really required.
https://www.ni.com/en/search.html?pg=1&ps=10&sn=catnav:sup.exm&q=3d%20picture
