3d grahp
Hello community.
I'm trying to plot the solution temperature distribution T (r, z) of a heated base and the lower side convection and top cylinder. The solution contains the temperature for all values of "r" (cylinder radius) and "z" (height of the cylinder). I wanted to graph the solution on a 3D graph but not how. I hope your prompt help.
Thank you
(3,084 Views)
Do you have an inmage how it should look like?
Most likely you can use a parameteric 3D surface graph with a color matrix wired. Here's an example fo hw I use it to display spherical harmonics.
What is your LabVIEW version?
(3,064 Views)
My version of LabVIEW is the 2014. I plot the data in a chat intensity indicator. The resulting image is the temperature distribution but viewed from the front as a square plane. It is a good approximation. But I would now see the distribution view from the top, like a circle. Now I have to hand the VI realize. I hope upload it then, if you have some code that I would serve me as much. Thank you
(3,049 Views)
Are you sure you are using an intensity chart, not an intensity graph? Big difference. A chart would not make a lot of sense here.
(3,040 Views)
