8 bit CCITT CRC
I am attempting to generate a 8 bit CCITT CRC with the 9-bit polynomal U8+U4+U3+U2+1
I have studied and attempted to modify the 16-bit CRC calculator found Here and the Vi posted by Shoneill here, but I am getting nowere..
CRC generator should be initialized to 0, LSB is sent first.
In the datasheet I found the example:
Data 1 : 1010 0000
Data 2 : 0000 0011
CRC :     0010 1010
Any assistance to how I can modify the existing 16-bit calcultors, or would it be a better idea to start from scratch?
(4,053 Views)
Accepted by topic author Jan_HeG
Solved. Modifying the vi by shoneill did eventually give me the result I needed.
(4,039 Views)
Jan_HeG could you share your code here?
Thanks!
(2,844 Views)
