11-26-2009 04:20 AM
I am attempting to generate a 8 bit CCITT CRC with the 9-bit polynomal U8+U4+U3+U2+1
I have studied and attempted to modify the 16-bit CRC calculator found Here and the Vi posted by Shoneill here, but I am getting nowere..
CRC generator should be initialized to 0, LSB is sent first.
In the datasheet I found the example:
Data 1 : 1010 0000
Data 2 : 0000 0011
CRC : 0010 1010
Any assistance to how I can modify the existing 16-bit calcultors, or would it be a better idea to start from scratch?
Solved! Go to Solution.
11-26-2009 06:26 AM
10-31-2014 04:45 AM
Jan_HeG could you share your code here?
Thanks!
