08-23-2024 10:10 AM - edited 08-23-2024 10:24 AM
903x
08-23-2024 11:40 AM
@Shivakumar_naganoor wrote:
903x
Use a boolean control and set the "Mechanical Action" property to Latch when released.
08-23-2024 02:47 PM
903x
Tools > Advanced > Clear Compiled Object Cache...
08-23-2024 05:03 PM - edited 08-23-2024 05:22 PM
903x
I'm not sure what your reply is getting at for the OP. I suspect that you felt like it might have been a joke continuation.
A "903x" is a common SPST physical push button switch with LED of color x that "Clicks in, Clicks out." It physically has a Latch when Pressed action off-on and Latch when Released on-off. With the indirect use of a mouse, rather than direct physical contact by the user, Latch when Released is the proper way to emulate the physical behavior of this type of switch with a LabVIEW UI.
My previous reply was simply Calibration of my Magic 8-Ball.
EDIT I guess that should be Switch When Released! I'll write up the 8-Ball out of calibration report.
Stop laughing crossrulz! I am having a bad day 😉
08-23-2024 05:19 PM
@JÞB wrote:
903x
My 8-Ball says its the 903x cRIO series. Anybody want to wager? 🙂
08-23-2024 05:29 PM - edited 08-23-2024 05:32 PM
@mcduff wrote:
@JÞB wrote:
903x
Sure, but the wager must be low and the new, bluebar OP needs to introduce (select any or none pronouns) on a new thread on Breakpoint linked here for payoff. I may have had a bad day. And, you have no 8-Ball!
